Keep on trucking!
And dive into the purple haze with DEEP BLUE’s latest release the Juggernaut 5 which introduces one of the rarer colors seen the horological world – purple!
This vibrant, vivacious and sometimes valiant color used for the United States military’s highest decoration, makes an unexpected appearance on DB’s latest tool diver.
But, if purple isn’t your thing, then in true DB style, the new Juggernaut is offered in a full range of colors; I have cherry picked out a couple black and blue combos that I think you’ll appreciate.
More of a large truck these days than a full on juggernaut; the watch is offered in a manageable 44mm diameter and is made from 316L Stainless steel. Water-resistance is 1’000ft or 330m.
Its engine is a reliable Swiss made Sellita Sw-200 automatic movement with a beat-rate of 28,80vph, 26 jewels, Incabloc shock protection, a date function and custom DB rotor - displayed via a see through back.
Diver’s feature of the Juggernaut 5 include: a screw-down crown and case-back, a luminous ceramic 120-click unidirectional diver’s bezel and Sapphire crystal with AR-coating.
The watch’s winding crown can be found nestled within an integrated crown-guard the 9 o’clock position while a manual Helium Release Valve 10.
By the way no matter which dial color you opt for, all feature a unique sunray wave pattern, all come with blue-colored indexes, minute tracks and hands with blue SLN lume.
The new Juggernaut form Deep Blue comes on a 22mm custom design soft silicon diver’s strap or an optional 22mm Stainless steel link bracelet with tension pin and collar, push button deployant clasp, 3x micro-adjustments.
Thoughts? The purple option, is what it is, an option that some will absolutely love and some will hate. But what do you think?
Keep on trucking!
