OceanicTime PANERAI Submersible Carbotech 47MM
This is the new Submersible Carbotech 47MM AKA PAM01616, released by Panerai, this week at SIHH 2019. The new Submersible Carbotech is dressed from head to toe in the high-tech material.
It gets a Carbotech case, crown-protecting device and unidirectional rotating bezel ensure extreme lightness and resistance. Carbotech has an uneven, matte black appearance, which varies according the cutting of the material.
The structure of Carbotech is designed to enhance both the aesthetics and the performance of the material. To form the plates of Carbotech from which these components are made, thin sheets of carbon fibers are compressed at a controlled temperature under high pressure together with a high-end polymer, PEEK (Polyether Ether Ketone), which binds the composite material, making it even stronger and more durable.
Basic spec. includes: an automatic mechanical, P.9010 caliber, executed entirely in-house by Panerai and 300 meters of water-resistance.
The new Submersible Carbotech is available in a standard 47mm diameter or a new 42MM size. It has an MSRP of 18400USD excl. sales tax.
