OceanicTime UNDIVE Dark Sea 500M
This is a new dive watch project due to be launched (if not already) on Indiegogo/Kickstarter.
The Dark Sea from a new brand known as UNDIVE Watches (I’m not sure if they’re any relation to UNDONE Watches or not).
Technical specifications of the Dark Sea are as follows: a vintage-style case available in either 316L Stainless steel or Bronze.
There are two Stainless steel versions; one with a steel bezel and one with a black PVD-coated steel bezel.
The case is fitted with a Sapphire crystal, a Helium Escape Valve and has 500 meters of water-resistance.
Its dimensions incl. a 45mm width (47mm incl. signed crown), a 50mm length and a 15mm thickness (15.40mm including crystal). The lug width is 22mm.
The Dark Sea has a Sunray dial with BGW9 lume. Power comes from a Seiko NH35 automatic movement.
Please follow the link embedded, below to be taken to UNDIVE website where you’ll find more info on their launch.
